85`318i at - mt swap from 91`325i engine possible?
  • freshiro
    • Feb 2006
    • 21
    i have a 85 318i at. as u all know. my cousin is about to sell her 91 325i cabby mt.. i know this is prolly a dumb question but .. cud that engine fit in my 318i? .. i was talkin to a friend he said to just take the engine/tran.etc off it and put it in my 318i.. i WOULD drive the 325i instead but its a cabb (( no offense to cabby drivers.. much respect )) and its more jacked up than my 318i. more dents. more rusted. needs a few new parts to get it to a daily driver.
    1985 318i. Norwalk, Ca 90650
  • Il Duce
    Non-Mod M42 Modder
    • 5046
    i bet it "cud" fit if you have the correct materials and instructions... dunno how hard it would be. to be honest, i just wanted to make fun of your grammar.
    • mikeedler
      • 6707
      is def. pos. my car was a 318i M10 now its a 2.5
      fit in there just fine. was a bit of work.
      • e30Matt
        • 5077
        As long as you transferred all 325 specific parts from the cab to your car, it should pretty much bolt in.
        • James Crivellone
          Head Janitor
          • 6305
          Direct bolt in swap,
          I would also change out the front and rear suspension and install 4 wheel disc brakes.
          We did all that on mots car.
          You will run into electrical wiring issues (IE you gotta convert from old to new), unless you swap out the ENTIRE wiring harness (which may not be a bad idea depending on how far you wanna strip the car)
          • Spencer
            • 767
            I helped a friend do this swap last summer. We had air tools and a lift and it only took a day to get everyting in - electrical was another story. We swapped everything we needed from a donor 325i and it all bolted in like it should have
            -Spencer
            • MitchFong
              • Sep 2005
              • 665
              would you like a period with that sentence?
              • CleanAzzE30z
                • Jan 2004
                • 11794
                Mike Elder. You bastard. I love your car (red one in this particular case). That is all.
                Mariano
